no leaks at allcheck for leaks....
no im not running a restrictor and tomorow im gonna check the charge pipes 2 c if got oil thereyou didn't answer the q tho. are you running a restrictor or not? an improper drain would also lead to bad seals. take off the hot side charge pip and check the compressor for oil. picture of your drain line? it should be facing downward, with no kinks or sharp bends and should be as direct as possible.
if you checked the seals of the turbo and found no residual oil then it could be your rings. you can do back to back compression tests to check. look up wet vs dry compression test. you do the test, then fill the cylinder with a bit of oil, the oil fills up broken/cracked seals and if you see a HUGE bump in compression then it's likely to be bad rings.
-Luke
k. keep us posted and take a picture of your drain line if you could.. also, you should think about getting a restrictor in there. overtime that high pressure will start wearing down your seals. trust me i know from experience.no im not running a restrictor and tomorow im gonna check the charge pipes 2 c if got oil there
yea im looking into getting one right now....and yes i will take a pic 2nite once i go 2 the garage bcuz i only drive my car when is nice out....otherwise i drive my beater neon hahak. keep us posted and take a picture of your drain line if you could.. also, you should think about getting a restrictor in there. overtime that high pressure will start wearing down your seals. trust me i know from experience.
-Luke
bad news ppl turbo seals are blown...checked my charge pipes 2day and there is oil all over the place..Either the turbo needs a rebuild or your rings are shot. Have you done a compression test?
