Yep the engine light suddenly comes on and the car cuts off, like these both things happen at the same time. The scanner shows the cam sensor faulty I dont know the code as the mechanic did it. This problem only happens if I drive the car for more than 30 mins or sometimes after an hour or so. But when it happens the if I try the ignition the car starts again and then shuts off in less than a kilometer. But if I park the car for a few hours it drives fine until I drive it for more than 30 mins
I remember one incident when the car went off, I just went to neutral and started the car and kept on driving it. I did it like this for four times until I reached my destination. The distance covered was 86kms. But while coming back after driving for 15 mins or so the car went off. I started the car again and drove and the next time it went off it would start and cut off instantly and after repeatedly starting the car, the engine started giving back fire sounds. Then after 2 mins I tried again this time I barely took it off the highway and went to a near by mechanic. He changed the O2 sensor and according to him he kept the car running idle for a few hours the car did not cut off. But when I took the car from him and was coming back, after an hour or so the same problem started again. The mechanic did say that cam sensor needs to be replaced as well. The thing is I want to be certain that changing the cam sensor will solve the problem
