im hopeing some1 on here is good with electronics because im not but my problem is every time bass hits my inline fuse blows in ive had this system for 2 years in this just now happening my setup is basic 560 watt amp in one 12 inch sub any clues to why it keeps blowing in what i can do to fix this
thanks
could be a few answers. try to give as many details about the system as possible. what kind of amp, what gauge of wire used in the install, what size fuses are in the amp, what size is the inline fuse? wattage doesnt mean anything in this situation.
bad amp? power wire shorting to ground somehow? i would definately double check all the power wiring and see if, over time, you may have developed a small cut in the line somewhere that is shorting.
when the bass hits you are drawing the most current from your amp. output stage of the amp could be fried. hook it to a buddys known working system for a monemt to see if it repeats.
