whats wrong with having anything welded? in most cases if theres a specific exhaust setup you want you will have to have something welded on your exhaust... for example when i went header and full exhaust it was too solid so i had to weld a flex pipe inif anyone could recommend a decent header with a 2.5 inch outlet, it'd be much appreciated. I'm seriously trying to avoid having anything welded.
I didn't say there was anything wrong with having something welded to my exhaust, because right now its completely welded except for the connector between the header and the cat. I would just simply like to avoid such measures because 1.) I do not know how to weld. 2.) I do not own a welder. and 3.) I would like to install the exhaust myself.whats wrong with having anything welded? in most cases if theres a specific exhaust setup you want you will have to have something welded on your exhaust... for example when i went header and full exhaust it was too solid so i had to weld a flex pipe in
