By learning Japanese lol. Learning Hiragana and katakana helps but it's still kind of hard.May i ask how you translate japanese to English, its weird coming from Google.
plans to run harness through the hole?Got hit up by Xavier of Wireworx on Friday saying my harness is nearly completed and he suggested I grab a Ktuned water neck to round off my K24. I was looking into it in the past, so I went ahead and took his advice. Ordered one of those and a thermostat plug. Heat will now be deleted.
i thought he had cannons?plans to run harness through the hole?
My harness is setup with an "over the valve cover" style, so all the ECU connections and sub-harness connector will hide next to the passenger side shock tower and go underneath the battery tray through the factory wiring harness hole.i thought he had cannons?
Good plan!My harness is setup with an "over the valve cover" style, so all the ECU connections and sub-harness connector will hide next to the passenger side shock tower and go underneath the battery tray through the factory wiring harness hole.
what's your plan then where the heater hoses would be? you have thought everything else out on the car so Id guess you have an idea for that alsoMy harness is setup with an "over the valve cover" style, so all the ECU connections and sub-harness connector will hide next to the passenger side shock tower and go underneath the battery tray through the factory wiring harness hole.
Either making use of K-tuned shifter cable grommet, or just a carbon fiber blockoff.what's your plan then where the heater hoses would be? you have thought everything else out on the car so Id guess you have an idea for that also
Ayyyyeeee
600 for the engine harness. Not too much if you don't want all the extras like raychem sleeving, breakout connections, labels, and crap like that. Another 300 for my k series plug and play subharness with an added obd2 diagnostic port.what does a custom/semi custom harness run? ball park, as im sure you got a discount.
