the most impressive thing was the torque it retained for a b16. Peak power was down a bit when you consider it was a jdm b16a. It was a fun car but wasnt nearly enough for what I wanted. Turbo was my next step for performance, I even had a setup worked out with Greg from go-autoworks.For what it is that's not bad for a stock motor.
Yes and yes. Fujita didnt have a proper 3" and the cost of intake showed that. I should have went with AEM or Injen for a 3". I wasnt concerned with max N/A output and I only went with that cold air because I basically got it free. Sold my carbon fiber intake for the price of the fujita for a little more top end power.Was t that a Fujita CAI for the integra? If so was it the ls/gs ?
jesus, that thing is clean and down to the p oint.daily driven
I considered it since the TSX has the provision for it without any tapping necessary, but I also considered that this motor won't be seeing the same revs or stress without seriously racing so it should be fine as is. Same thing with the Rsx-s or S2000 oil pump. I don't plan on doing the extra revving, so i'm going to enjoy the smoother and balanced stock pump.Swap related question here!
Have you gave any thought about using the factory k20a2 oil cooler on your k24 block? I have been seeing several k24 guys do this conversion.
Brake fluid will also eat up the paint in the bay.Use that orange auto zone hand cleaner and some degreaser from auto zone along with brake fluid I swear to God brake fluid eats s**t up good.try those itll do you good .
Sent from my SGH-T679 using Tapatalk 2
Hey CHILD What do you recommend to clean up oil off a motor etc. On my last posts on my build you can see what i'm talking about. Basically there's a thick thick coat of oil on my block/head from where the previous owner had a valve cover leak and just let it leak and kept putting more oil. So it has massive amount of oil covering it.. Thanks
^^^^^^^I think child swears by simple green.
K-tuned RSX billet shifter and running my race spec shifter cables through the heater core outlet at the firewall. Still a bolt in affair, no worries about seized shifter cables due to exhaust heat, more space to tuck the exhaust closer to the body for more ground clearance, and more blingWhat are you going with now?
