I agree with you but also would like to I want to add to this.Generally speaking there's nothing wrong with having parts manufactured and/or imported from other countries. In all honesty I would do the same if I were ASR because cost of production will decrease and keep them in business and making profits. It's a smart business decision. That's not to say the quality suffers. What's most important is the engineering behind it. Using the right design, materials, grades, tolerances, etc.. What a lot of these companies do is engineer them, send the specs/blueprints overseas to have them manufactured and they sell them here. It's common and I know many other highly reputable afternkarket parts do it.
Blox on the other hand is garbage. I speak from personal experience using and seeing their products. Sure some of their stuff might work but when comparing them to ASR, they are far behind..
I don't have anything against a tie bar that is designed well, beaks is a terrible design. A tie bar is a very minor increase to rigidity... but worthy enough to a standard part on the ek9 civic type r and dc2 integra type r for example. I wouldn't discredit the function or purpose of a part just because they're bad examples in use.Rear looks good, glad you didn't put a beaks bar too. It's just silly seeing it with a brace. That's sufficient enough.
"beauty"Cool,The groove on them, what's that for?
the main thing is just to separate them from other people who decided to start selling bolts and beauty washers. Frank "downstar" has been focusing on doing everything even better or adding little touches lately.Cool,The groove on them, what's that for?
thanks man. I get carried away with things, but I like having little things to tinker with lolkerry looks saucy. im still hooked [even if you spend silly money on trinkets]
I love the rear sway, it was a dramatic change to the handling. Im running a 22mm front sway with the 24mm rear. Feels great. What im not liking currently is my wheel setup since I have basically 0 camber in the rear and the wheels are more inboard than I prefer. Id say to get the rear sway if you're interested along with a front one if you dont have one. Just guessing, but I think this rear sway alone would be a bit too much oversteerHey! This thread moves so fast I don't have time to read the last 54 pages, but I was wondering how you like the 24mm sway bar? Do you have just the rear or are you running a front too?
That's awesome, because I was looking at that same one. I was thinking about doing a 24mm front (I was talking to a guy that time trials his EG hatch, but since the chassis are different I didn't know if that would work the same for mine). What's super irritating is that I am wanting to keep the Civic now and do time trials with it every once in a while, since I have a bike and a daily now...I love the rear sway, it was a dramatic change to the handling. Im running a 22mm front sway with the 24mm rear. Feels great. What im not liking currently is my wheel setup since I have basically 0 camber in the rear and the wheels are more inboard than I prefer. Id say to get the rear sway if you're interested along with a front one if you dont have one. Just guessing, but I think this rear sway alone would be a bit too much oversteer
The over steer would be dependent on the other suspension mods, alignment and tire setup. Also driver preference. On my '91 Si I removed the stock front bar, have an adjustable 22mm rear bar and (had) a 450/550 spring rate, with an aggressive alignment setup and tire pressures set all to induce over steer. For some it's too much(they end up spinning when driving my car lol) but for me it is exactly what I liked and I never had an issue. If you're thinking about time trials you should go out with the car as is to use as a baseline before modifying. You can easily waste hundreds to thousands if you mod first then change your mind after you really understand your car and what you want out of it on the track.That's awesome, because I was looking at that same one. I was thinking about doing a 24mm front (I was talking to a guy that time trials his EG hatch, but since the chassis are different I didn't know if that would work the same for mine). What's super irritating is that I am wanting to keep the Civic now and do time trials with it every once in a while, since I have a bike and a daily now...I hate my fickleness sometimes.
That makes perfect sense to run it before I mod, and see what I would like to change. At the same time I'm researching on very common simple mods to do (i.e. the 24mm sway).The over steer would be dependent on the other suspension mods, alignment and tire setup. Also driver preference. On my '91 Si I removed the stock front bar, have an adjustable 22mm rear bar and (had) a 450/550 spring rate, with an aggressive alignment setup and tire pressures set all to induce over steer. For some it's too much(they end up spinning when driving my car lol) but for me it is exactly what I liked and I never had an issue. If you're thinking about time trials you should go out with the car as is to use as a baseline before modifying. You can easily waste hundreds to thousands if you mod first then change your mind after you really understand your car and what you want out of it on the track.
I always explore what the car does as is before making a change that I feel I want/need. I'm not on a track but my play roads is where I test everything out. Once I get used to this setup I'll adjust the rear sway if I feel the need. My biggest conflict is visual appearance and performance. So I'm trying to find my happy medium.The over steer would be dependent on the other suspension mods, alignment and tire setup. Also driver preference. On my '91 Si I removed the stock front bar, have an adjustable 22mm rear bar and (had) a 450/550 spring rate, with an aggressive alignment setup and tire pressures set all to induce over steer. For some it's too much(they end up spinning when driving my car lol) but for me it is exactly what I liked and I never had an issue. If you're thinking about time trials you should go out with the car as is to use as a baseline before modifying. You can easily waste hundreds to thousands if you mod first then change your mind after you really understand your car and what you want out of it on the track.
Ahhh.... you're making me miss my car.I always explore what the car does as is before making a change that I feel I want/need. I'm not on a track but my play roads is where I test everything out. Once I get used to this setup I'll adjust the rear sway if I feel the need. My biggest conflict is visual appearance and performance. So I'm trying to find my happy medium.
