It worked to start the car and idle roughly. I've been working out fueling and wiring kinks. Found a few things that needed to be switched or moved around. Also, my battery is flat and giving me a 'low voltage when cranking" error in the codes section of kpro. It's not to hard to make a map if you use a preset one as a starting point. I don't believe my problems are with the maps but with minor things like wiring.
Yessssss.
Did your basemap that you make not work? I have been wondering how difficult it is to make a custom map with KPro
I'm confused I thought this was going into a red EK hatch?
Glad to see you follow the build so closelyI'm confused I thought this was going into a red EK hatch?
It is 300+ pages, cut him a breakGlad to see you follow the build so closely
The coupe is an HX submodel so it was a D16y5well, MY calendar was way off! I thought the swap was going to happen in March. I really like the fitment of that Apexi exhaust. seems really tight, no rubbing. I guess this is also the first time seeing the old engine. Was that originally a d16y7 engine, with a y8 intake swap?
I have a Vibrant filter for the V stack, just not on while in the garage. Just wanted to get things going.Very impressive work.
No air filter though?
Plain link to startupLink is broken to the YouTube vidat least on tapatalk
There's about a couple of inches of clearance. Ill have to measure but it's more space than it seems in the pics. Same with my harness near the header, there's more than 2 inches for sure but it looks close at a glance. The mounts aren't that bad at all even for being brand new. The vibration that's annoying for now is little pices pieces of interior trim that aren't new and rattled with the stock motor. The mounts will soften over time and it'll be smooth amd quiet but the engine will still sit firmly in place. I had the same mount setup with my old b16a.How much clearance between the motor/belts and the passenger side shock tower/frame?
How's the vibration through the chassis with the race urethane mounts?
I just didn't see it on my feedShe has Instagram
It livessss!!!!!Plain link to startup
http://www.youtube.com/watch?v=TVi7SSGsnNk
Be warned, it's addictive... mostly because it makes all your normal stuff look hella out of place lol.I just didn't see it on my feed
It livessss!!!!!
Btw, damnit you. Now I'm looking at engine dress up parts because of you!
