when is the vtec-e crossover? 2500 rpm is what i found hereBecause that's where the sohc motors start to pick up power. The vtec-e crossover isnt even at 2500rpm btw.
it's between 2500-3000rpm depending on load. It won't be a consistent 2500rpm unless the conditions are exactly the same every time you accelerate.when is the vtec-e crossover? 2500 rpm is what i found here
http://en.wikipedia.org/wiki/Honda_D_engine#D15Z1
and appeared consistent with my findings today.
yes, vtec-e is designed to save fuel by operating with basically one intake valve at low rpm. however, at a designated rpm crossover point, the second intake valve will begin opening fully, resulting in increased power. i don't know how anyone can say a driver won't notice when 4 more intake valves start opening.The vtec-e does cross over earlier as it is designed for lower RPMs, but it is NOT anything you are going to feel. It was designed for saving fuel.
You are mistaking vtec-e from the d series to the b series. B-series is noticeable d isn't.yes, vtec-e is designed to save fuel by operating with basically one intake valve at low rpm. however, at a designated rpm crossover point, the second intake valve will begin opening fully, resulting in increased power. i don't know how anyone can say a driver won't notice when 4 more intake valves start opening.
i've driven lots of sohc vehicles and getting into an engines power band is very different from what i am describing in the vx. when the rpm climb into an engines power band, it is a smooth transition. what i am describing with the vx is a very clear on/off, sudden engagement.
here's a link that explains vtec-e pretty clearly. not specific to the d15z1 but the same principles apply.
http://www.b18c5eg.com/VTEC/sohcvtece.html
Amen to that.Every power band especially in stock form isn't smooth all the way through. If it was, there wouldn't be a need for tuning.
