Lol that's the exact one I have too. I tried bleeding with the pedal extended and compressed. Still no luck. When I replaced both hydraulics, I got Duralast, cause I didn't have the money for the OEM from ordering the wrong part originally. Looking at Exedy ones just in case the Duralast ones are doneThis tool allows you to do it yourself, if you have an air compressor.
https://www.harborfreight.com/automotive-motorcycle/brakes/brake-fluid-bleeder-92924.html
Yep used the alignment tool. Brand new throwout, pilot, and flywheel. Drove it around the block it shifted fine. Let it sit for a while. Drove it further then started acting up. Ended up parking it, don't wanna mess anything up. And have to go back to square one.Did u center the clutch while installing it? Replace throwout bearing?
Sent from my iPhone using Tapatalk Pro
Originally tried the part below with the pedal depressed, didn't notice anything. So I re-did everything but with the pedal all the way up.The pedal should not be depressed when you use the tool. Are you using it correctly? Describe exactly what you did or post a video.
Yep Duralast. Bought them, nothing happened then went deeper to the transmission. Decided to park the car, Cause I didn't want another spring to break out of the clutch disc as in the pic I posted. (Idk if I caused that or not, but just wanted to be safe)Are the MC and SC new?
Lol no fluid leak or air. I officially ride the short bus. I did the start in 1st to see that it wasn't disengaging. I bled it correctly.If there is no fluid leak, then the most likely scenario is that there's still some air trapped in the hydraulic system.
