sure, simple way would be to put it at TDC( top dead center) you can get it with out taking head off by take the cylinder number 1 plug (closest to the timing belt) and put a very long rod in it and turn the crank until the rod stops moving up and also take note that the cam gear has a arrow on it should be pointing upward by the teeth of the gear there will be 2 lines engraved directly opposite to each other.I just bought the new plugs and the seafoam, will let you know what I find.
