rockinout5432 said:
Thanks for the replies, guys. It's been helpful. I have a question for Rob, though. I won't be able to run 10 psi of boost on a stock motor, right? Also, my car is high mileage for the year (107K), so how will that affect turbo performance and longevity?
You can safely run 10psi with good tunning done on a dyno so you can see the air/fuel ratio of coarse you're going to need some good engine management. i'm using an apexxi vafc & dsm450 injectors. i'm running 10-11psi on a stock intenal b16 dyno tunned 250 horeses at the wheels. i've never hade any problems with it. as far as your milage 107k miles is stil very reasonable for boost. there are guys running boost on engines with 170k miles +. you're pistons, rods, or sleevs are what can break if you don't have good tunning. even though your engine has 107k miles the internals haven't recieved much abuse. unless you've ran 10 100hp shot of NOS tanks through it. check out those web sites that where recomended. most of the engines on there are over 100k miles young. "It's all about the tunning" you'll need a stronger clutch if you're gonna boost too. Hope you don't mind if I post pics of my baby:
boosting 10-11psi 250whp
nissan .60 trim t3 w/custom made tubular manifold
ebay front mount ic & rfl BOV
apexxi vafc & dsm 450s
2 1/2" mandrel charge pipe & 2 1/2" exhaust no catalytic
turbo xs manual boost controller
weapon r coil overs w/camber kits
ebay short shifter & type r shift knob
