Green Machine said:
i would get rid of the motor you have now though it is a non-vtec motor
HX D16y5 = VTEC-E, 115hp. The hx is a vtec, a strange one, but it is still vtec. However the d16y5 is somewhat of a mixture of a DX and an EX. The intake manifold of the hx is similar, even though the ex still flows better. The hx head is designed similar to the ex, except it has roller rockers, another plus. Unfortunately the hx share the same exhaust manifold as the dx, lx, cx...having 2 oxygen sensors and a cat inside the manifold. Another disadvantage is how vtec works, the hx works on 8 valves I believe until 2500rpm then vtec engages all 16 valves, thus better fuel economy. It also has the EGR valve on the intake to the left of the fuel rail (egr=exhaust gas recirculation). The tranny kinda sucks too, if you have the automatic it is a CVT continuously variable transaxle, if you have the manual you have very long gears which wouild suck for a 1/4 mile but highway boosting for instance would be cool. If you decide on turbo, I would do a mini-me swap with the ex head, intake manifold, ecu, exhaust manifold, and tranny if you want to. The hx is boostable while retaining all the parts i just described, but fuel management is tricky. The apexi VAFC wont work because even though the hx is vtec, apexi doesn't have their unit to work with it. You could probably go with an SAFC or an FMU if you plan on staying under 10psi. Hope this helps.....
I also own a 98 hx 5-speed and im still debating on either a mini-me/turbo or b18c1 swap. I guess i'll get the cash first and decide one i have it.
