Yes...and the auto 98 DX TB has a 3-wire IACV.One more thing. The throttle body is coming from an automatic 98 dx. Will all those sensors and iacv work with my car?
Just use a wire of the same gauge as the other IACV wires.Now just trying to figure out the wiring. Is there a certain type of wire I need for that extra one or where do you suggest getting that wire from.
Go to a junk yard and buy some 96-00 Honda Civic ECU connectors. Depinning connectors is not difficult. Just solder the wire to the pin and insert into the current ECU connector at the correct location.And also was looking on the wire connector that connects the wires to the computer. How do I add that new wire in there? Do I need to somehow open up that clip and then put that wire in there.
Did you read post #17?But just to make sure I just need to do the reverse of this picture? correct? thanks!
http://www.ff-squad.com/tech/wiring/wiring.99-01_b-plug.jpg
yea, its just confusing because the numbering on the actual plug itself is not the same as what people are saying the pin numbers are...It looks like on the plug that it goes from 19 (on the right) to 25 (on the left), so i would assume that the blue/black wire is in pin 21, but the pictures say that its numbered the opposite way and its in pin 23Did you read post #17?
Yea i bought some shrink wrap insulator at the auto store, but none of the auto stores could match the wire gauge and neither could home depot. I havent tried lowes. And im getting different answers for the gauge also, some say 20 and some say 22...is there a definite answer?You should be able to match the wire gauge at Home Depot, Lowes, etc. Regarding wire splicing, soldering and shrink wrap insulating are the way to go.
Try other hardware stores as well, or even Radio Shack. Just bring a snip of IACV wire with you to match. If it's close, you'll be fine.Yea i bought some shrink wrap insulator at the auto store, but none of the auto stores could match the wire gauge and neither could home depot. I havent tried lowes. And im getting different answers for the gauge also, some say 20 and some say 22...is there a definite answer?
