d16z6 turbo setup
clifford_05
Rockin the d-series
here is the build....
Turbocharger
>GReddy turbo kit
>Intercooler Kit: Small One
>GReddy Type-S blow off valve
Motor
>Ex/Si d16z6
>1 Step Colder Ngk Plugs/ Ngk Wires
Tranny
>Stock Ex/Si Tranny
Clutch
>Stage 2 clutch kit
>Resurface stock flywheel
Tuning
>P28 Ecu
Gauges/Electronics
>Autometer Boost Gauge
>Autometer Air:Fuel Meter
>Autometer Oil Pressure Gauge
>GReddy Turbo Timer
>GReddy Profec B boost controller
stealthy
4 Doors For More Whores
id get the zex cam. ignition isnt anything id rush into, its not a big concern, stock is fine unless you are making crazy b series power. base your injector size uppon estimated hp, you want about 80% duty cycle, too big can hurt you and too small can limit you. forget the vafc, uberdata has you covered for everything you need basically.
snoob
9k RPM and 1+ Lateral G
sounds alittle extreme...
what are you trying to do with this thing? if you want a DD you can push 200whp with much less than this reliably... of course alot of it is in the tune.
clifford_05
Rockin the d-series
well if this sounds a bit extreme, then what would give me good reliably and still put out good numbers?? im lookin to push around 8-10psi
stealthy
dont go my how much psi you want to run, everything is according to your hp goals. hp breaks stuff, not boost
clifford_05
Rockin the d-series
well what would be a good number to shoot for on a z6 with a turbo kit??
clifford_05
Rockin the d-series
stealthy said:
ok, what would i want to do to my motor to have good relibility for a dd?? and i know im gonna want a real good tune..
TiiM iiS l3eAsT
Scamming Piece Of s**t
all u need is a really good tune if your going to stay around the 200's.....if u ever want to kick up the psi to around 15-20 i would say start changing ur internals( rods, pistons, sleeves)
stealthy
1999CivicEX said:
if you want 200 hp I would sleeve or atleast block guard that b***h =D
sleeves for 200hp.......just give the money to me instead
clifford_05
Rockin the d-series
alright guys, all i want to do is build a d16 with a turbo kit and push around 200whp, or even like 180whp because it would be alot faster then what i can do right now. i just want to make my car a bit faster so i can have alittle more fun with it and get my first speeding ticket, lol . i dont want to spend tons and tons of money doin it. so i guess i just need to know what i would want to do to my motor to give me a decent whp number. would i want to change the pistons, rods, valves, springs and retainers, and stuff like that. and would a p28 chipped ecu be fine?? ill prolly put some block guard on it because that aint real expensive, i mean i found some golden eagle block guard for $87.
TiiM iiS l3eAsT
for 200 whp u wont need to change any of ur internals just run a T3 at around 10 psi and u'll be set
clifford_05
Rockin the d-series
so all i need to do is get the motor, swap it, throw a t3 turbo on it, run 10psi, with a really good tune and ill be fine?? and i wont have to change anything on the motor??
racing_kid
take that sucka!!!!!
a friend of mine hit 200hp in his d16y8 off a small turbo at 10 psi
a bad ass tune.
stock internals
home made turbo kit.
fmic.
Im sure you can hit it with what you have as well.
oh yea...you might need bigger injectors.
clifford_05
Rockin the d-series
thanks for the info guys. im just gonna get the stock motor, and throw a t3 turbo kit and an intercooler and then ill get a p28 chipped ecu and ill be done with it and ill see what happens from there....
TiiM iiS l3eAsT
yes thats it....with that tune make sure u get 310-450cc injectors...
clifford_05
Rockin the d-series
MasterShake said:
i like the new list better hommie :thumbs up
lol, thanks man. i kinda cut ALOT of s**t out because i listened to other ppl and im gonna trust em. i dont know if its a good idea but ill see what happens :lol:
