rotating is easy..just loosen up the 6 bolts on the turbine side and the exhaust side and rotate..dont tighten it until you have your oil return line set to a place where you know its going to stay, since you have to drill your oil pan anyway you dont want to tighten it now and have to loosen it later cause you have to clock your turbo a few degrees to have better oil return flow
