the larger of the two.. and i used the replacement sockets for autometer gauges...Lil_falco said:These are the right numbers but Im wondering what the bulb number of the one you ADDED is...
Right... What?oc_civic said:the larger of the two.. and i used the replacement sockets for autometer gauges...
the size of the extra ones will depend on the socket you use..
gearbox said:a word of advice, those premade led bulbs usually do not last very long. reason is almost every one of em is resistored for 12v, well when running the car puts out around 14v and sometimes as high as 15.5v so, expect them to slowly fail by being overpowered. should last no more than a year depending on how much you drive. i would only use those bulbs in dome lights and other apps where they wont be in constant use when the car is running.
the LEDs in the dash? u can just dim themgearbox said:a word of advice, those premade led bulbs usually do not last very long. reason is almost every one of em is resistored for 12v, well when running the car puts out around 14v and sometimes as high as 15.5v so, expect them to slowly fail by being overpowered. should last no more than a year depending on how much you drive. i would only use those bulbs in dome lights and other apps where they wont be in constant use when the car is running.
WERD.tjlucas said:the LEDs in the dash? u can just dim them
pretty sure that168 and 194 are the same bulb...Lil_falco said:thank you. And you mean "1 extra socket" right? for the ONE extra bulb...?
So 2 #194's, 2 #74's and 1 #168?
i just bought a house.. my wheel bearing has been f**ked for 2 weeks now and im JUST fixing it sunday... so that gives you some idea of the limited amount of time i have.. its very simple..oc_civic said:pretty sure that168 and 194 are the same bulb...
and yeah that sounds about right.. although i used two extra bulbs.. you just have to put it together and SEE where YOU need more light.. thats where the extra bulbs come in
oc_civic said:
Lil_falco said:And that looks like a bulb, not an LED....
Here,s what I found. Can someone confimr that this is EVERYTHING i will need...
3 of 194 NEWEST SUPER STAR http://autolumination.com/194.htm
2 of 74 TRI-POWER 3 LED BULB http://autolumination.com/74.htm
