Decided to Boost D
VTECDreaMs
VRR
Well, for those of you who saw my last thread... I've decided to boost a dseries. I just figure i can get more power for my money and me being 17, sounds more ideal. (Plus my insurance would've been nuts with the ITR so i said forget it)
I'm looking for an EG Hatchback(Preferably Si, I want D16ZC) My next question is, if i find one for under 5k...Should I build the ZC and then boost it, tune it.... or leave it stock.. boost it and tune it.(Keep in mind the mileage will probably be high) I'll have around 3-4k to spend on this project.:thumbs up
What do you D-Series guru's think?:what:
itsmycookie
#1 a*****e
i would build it then boost it so if you ever wanted to increase the boost later on you would already have the engine built for it. plus with a high milage engine you never know on how high you can safely boost them. better to be safe than sorry and blow it up.
VTECDreaMs
VRR
^^Thats what i was thinking BUT can i build it, and then come up with a good kit for under 4k? I wouldnt be able to do the rebuilding of the motor myself, so think of labor(65$/hr, found a shop) and add that to the tab. :|
itsmycookie
#1 a*****e
it matter wether you;re going to buy a turbo kit or make your own. if you made your own i think you;d be able to build it as well but if you have a turbo kit you might be tight. try asking on http://www.turbod16.com/ there are some awsome people over there who know everything about boosting d-series.
Inigo Montoya
powered by boost
Si's come with d16z6's notZC's. ZC's are JDM.
Build your own kit... Im feeling generous today so Ill write this rant yet another time....
First and foremost: TUNING.
TUNING
Uberdata. (uberdata.pgmfi.org)
Need: 27c256 chip, 2 1.2ohm resistors, jumper wire, 28 pin ZIP, 28 pin ZIF, Wilems burner, 74HC373 blank chip... digikey 296-1591-5-nd
Optional: Wideband o2, EGT gauge
Cost:
About $70... optional add another $350-500
FUEL
Walbro 255lp
DSM 450cc Injectors
Resistor Box (DSM or Older CRX/Civics)
Cost:
~$200
POWER PARTS:
1st/2nd Gen DSM BOV
2.5" IC/charge piping
MHI Turbos: 14b, 15g, 19g.. GAR: T25, T28, T3, low AR T3/T4
JRIC 5" IC, DSM side, Volvo front, Subby Top...
2.5"/3" Down Pipe
HF,HX, STD manifold (older CRX's)
Cost:
$300-600 depending on how much you shop and look around
MISC
Couplers
Clamps
Oil lines
Vaccum Lines
Boost, Oil Temp, and AF gauge
Cost:
~$200
bmyers4321
timmy the testie rules!!!
instead of boostin a D why dont you swap in something better then boostin it later. im sure you could find a b16 or b18 and swap it in with some left over. here is one that someone suggested on a diff thread. if not from them look at some local junkyards they might have something.
hmotorsports.com
Inigo Montoya
powered by boost
hmotorsports.com
bad idea.
boost is cheaper than a swap and will yield SIGNIFICANTLY higher WHP/WTQ even at low boost levels.
bmyers4321
Inigo Montoya said:
bad idea.
yes that is true. but if a b series in the long run will be able to hold more power than a D. that is what i would do. but i am a hp freak. i dont have much on mine cause im stock but i would do the swap cause i would just wanna keep tryin to add more and more. but it is his choice so if he wants the turbo D that is cool. i know i wouldnt mind mine bein turbod. but i would like to swap first.
$lick Rick
TEOTWAWKI
oh so you're one of those "potential" people
to swap and build a b series to out perform the potential of the d series, you'd probably spend ~$17,000 or more...... that's why %99.9999999999999999999 of people that swap for "potential" never even come CLOSE to the potential of a properly built d series
and if you have $17,000+ to blow on a civic.... then you're an idiot for owning a civic in the first place :rolf:
Inigo Montoya
powered by boost
your right.. although I've seen b16's throw rods at 250whp just like D-series... bad tuning, but still.
plus 230whp is doable in a D, and thats PLENTY fast for a street car. And after the 200whp mark, it is a necessity to have upgraded brakes and suspension... including traction bars or a lsd so you don't snap your axles.
D is a nice $ check.. easy to replace.. good performance.. don't necessarily have to upgrade everything to run right... of course this is MHO..
bmyers4321
i agree with you totally. ask for hp there is no such thing as enough for me.
and yes slick rick i am one of those "potential" people. i know it sounds crazy to spend money to make a civic fast but that is the fun in building a fast car not buying one.
$lick Rick
TEOTWAWKI
remember though, buying a motor to having the potential and not using all of it is just a complete waste of money ;)
bmyers4321
agreed :thumbs up
stolle
if it were me i would get a dx with a d15 if your boosting you dont really need to worry about displacment or vtec for that matter the dx is gonna be cheaper too...
you dont need a bigger fuel pump just use some dsm 450s and a resistor box, uberdata, for low boost and an internally wastegated turbo i wouldnt go with exhaust bigger than 2.5" if you do you will get boost creep like a mofo, use a hf or standard manifold you will need an adapter plate for whatever turbo you will be using do a search on www.homemadeturbo.com . i recommend an IHI rhb5 turbo its relativly small and internally gated at 7 psi which is perfect for a stock motor if your concerned about longevity its compact and easy to work with and spools quick nice for driving around town . you can also use the intercooler from a ford probe (same car the rhb5 came from) along with the BOV since i have noticed that the probes are more likley to be in junkyards you can get a turbo on your car for dirt cheap for oil lines use bake hard line its cheap and works well last time i did oil lines i spent $4.17 on oil lines you cant beat that you could get all the hoses and fittings you need from ne parts store for under $100 dollars maybe even cheaper...
nemore questions?
24-7
E Engineering
I agree
Inigo Montoya
powered by boost
nemore questions?
i agree all in all, except for boostin the d15. the rods are sooo puny.. id rather keep the motor and buy a cheap d16a6/z6/y8/zc for boost.. then have a spare for if anything goes wrong.
boostedcivicd15
17psi + stock rods = oops
i blew my d15, it cost me $175 for a new engine AND a new transmission. they had 80k on them... i could blow 6 engines for what it would cost for me to build one... u decide
boostedcivicd15
mine held twelve psi daily for 3 months. and it only went because the wastegate broke and it spiked up to 17psi, pegged the damn boost gauge. this engine had 200k, no smoking, ran perfect (dialed out the a/f ratios on the wideband, and it allowed me to monitor it while driving), and screamed like a demon.
itsmycookie
#1 a*****e
i choose reliability-
ps your sig is way TOO big. max size is 500 x 100. change it or it will be deleted.
VTECDreaMs
VRR
Well thanks for all of of the replies.:thumbs up
Now I just need to find a car.:what:
If anyone knows of anyone selling one in Wisconsin, let me know some info. I cant really find exactly what I'm looking for. I want to spend 5k or less on the car, and about 3k to boost/supporting mods.
I still havent decided whether or not to build, I think at first im just going to boost considering im 17 and i need a car to get around and to my jobs. I dont really have the time to let the car sit in the shop and get built. More opinions would be appreciated.
TIA.
