core support is not necesarely needed, but if you do, than it will be bolt on, otherwise see my version of the howto:NOFX said:And core support.
Frontconversion Civic 96-98 to 99-00
What's needed:
- 99-00 hood
- 99-00 headlight units
- 99-00 front side fenders
- 99-00 grille
- 99-00 front bumper
For the people who try to use 99-00 bumper only... ITS NOT GONNA WORK. YOU NEED ALL FRONT PARTS. I made the following pic just to let those guys see the fitment difference with a 96-98 fender and a 99-00 frontbumper. Picture says it all!!!!!
Well, lets start the frontconversion when you have all parts as listed above.
1. Unbolt the 96-98 parts in following order: frontbumper & grille --> headlights --> fenders --> hood
2. Bolt on the 99-00 parts: hood --> fenders --> headlights
3. the grille is mounted on your bumper and you have to use the upper holes on your grille to
hold up your bumper and grille (in my case)
the frontbumper is the only fitment issue
see these pics
you have to cut/dremel a small piece of the bumper
then you can slip the bumper right in its place
unfortunately the holes are differents so you cant bolt these up! As i described above you
have to use your grille which is mounted on your bumper and use the upper holes on your
grille to hold up your bumper and grille (in my case)
Thats pretty much it.
It took me 5,5 hours to do on the street hahahhaha thanks to some friends who helped me out!!!! As a first timer, i think 5,5 hours is ok, but if i do it once more, it could be done in only 1,5 hours i think!
This is the endresult
Hope you can use this information to do your own conversion.
Greets,
Jordan
