differences in injectors
slowhatch
torque?
mavrick said:
dsm injectors are your best option. cheap, and they spray like civic injectors like everyone said.
the only thing is that i already have the stang injectors and i heard that a resistor box is expensive, like 100-200$
Shiznit
Stickin it to the Man
just get the appropriate resistors from radio shaq. you can do this with DSM injectors. 4 resistors shouldnt run more than $6 if i remember correctly
slowhatch
torque?
oh cool, do you know what type of resistors? like 4ohm 6ohm or 8ohm ? and you just wire them into the wires going into the injector?
Shiznit
yeah you wire them into the clips. the type of resistors you need depends on the type of injectors you have
Handlebars
None Taken.
for dsm's, and most aftermarket peak and hold injectors on a 92+ civic/teg, you want 10 watt, 10ohm resistors.
Handlebars
None Taken.
i got my used resistor box for 20 shipped, or you can spend 7 bucks at radioshack for the resistors you solder in.
Jay Jay
Administrator
Premium
Yup, 10 watt 10 ohm resistors wired in-line with the yellow/black wire. I believe they only cost around $2/2 pack
slowhatch
torque?
so a resistor for each wire or the black and yellow go into the same resistor?
thanks for all your help so far
Shiznit
you splice the black and yellow wire. there will be two prong type things sticking out of the resistor. solder one end of the black and yellow wire to one prong, and the other wire to the other prong. you only cut the black and yellow wire, for all 4 injector clips
slowhatch
torque?
oh i see, thank you.
