I'm nearly done with my Lexifying process (making my EK quiet like a Lexus). I've laid down 2-3 layers of Raammat in the trunk area, 2 layers on the floors under the front seats, 2 layers on the inside wheel weels and inside of the outer panel. One layer on the inside of the hatch panel, one layer on the roof. I then bought a few coats of rubberized sprayable undercoating and gave EVERYTHING a nice medium coat.
Next, I bought a few cubes of non-fiberglass insulation (like shredded carpet padding). Filling the quarters and wheel wells with it, and then using aluminum sheeting to seal the access holes. This will NOT let me fix dings from the inside anymore, but I have shaved moldings that wouldn't let me do that anyway. After this, the aluminum sheets will get a layer of Raammat.
Next, I cover the whole floor and walls with a layer of dry-cell foam. On top of this goes about .5-1" of carpet padding. All of the interior body panel seems will get fabric taped, and then it all goes back together.
I'm saving the doors until I get my power armrests recovered, and install my power windows.
The system should sound amazing when i'm done. When you take on a sound-deadenning project like this, it makes even crappy old stock speakers sound amazing because you don't loose any of the sound to vibration, or distort any of the sound with car-sounds.
It's a TON OF WORK. I've been doing it here and there in my free time and it's been about a month and I'm not done. It's not too expensive (about $350 in materials) for the results... it changes the car completely.
As for weight... Raammat weighs 0.5lbs per square foot. I used about 120sq. ft, so I added about 60lbs of weight. The foam, carpet padding, and undercoating weigh <15lbs.
Another good way to quiet your civic is to actually go to one of those Ziebart undercoating places. They coat the underside of the car with a layer of spray-on rubber (much like trucks bedliner), that keeps it from rusting, and keeps winter harshness from eating away the underside. A positive benefit is that it GREATLY reduces road noise and other vibrations. Typically it would take about 10lbs of material.
All in all, with the sub box and amp, I'll probably be adding about 150lbs to my hatch. Right now it runs a 14.4@98mph with a stock GSR motor, with I/E. I plan to go turbo in the spring, and 150lbs will be meaningless when you're boosted.... just add one pound of boost.
