Robo said:
Well i have completed suspension and looks and now its time for the engine. Ive got the wonderful D-series to work with, a 96 dx engine
![Crying or Very sad :cry: :cry:](/forum/styles/default/xenforo/smilies/icon_cry.gif)
Can a d series even get close to running low 13's with spending 1k or so or should i just swap her for something? I read about b18's all the time and never see any d stuff so i assume they are pretty worthless. but i swap would be much more labor so im just wondering if a d can get any ass for low buck, i could afford a turbo but have red they do little for the D. lemme know what u think.
yes, d's can get into low 13's for a grand and so can a b series. but that depends on alot of things. im not gonna get into it, cuz itll be way too long. but any d and any b CANNOT make it into lw 13's with 1k. turbo does little for the d?? kid, get your head straight. ive SEEN turbo d's beat a itr swap with i/h/e (in a cx). oh, and the kit he put together, cost him only 900 bucks. dont doubt the lil d, its the little motor that could.
low buck, 13 sec set up
ihi rhb5 turbo
450cc injectors
afc hack
mx6 / probe intercooler
255lph fuel pump
boost controller set at 10psi
done, there ya go. ofcourse youll need charge pipes, tubular manifold, down pipe, and resistor box, oil lines, vacuum lines, tapped oil pan. this is if you wanna go kinda low buck, to go lower, get a fmu and missing link....this way youll also NOT need the larger injectors or the fuel pump, but a high pressure inline booster.
edit: just read you post on spending no more than 2.5k. well you can swap a b16 for that, or you cn turbo your d pretty well. and if you go for the b16, congrats, you just choose to go slower. with 2.5 k you can do
garret t3/to4e (sized at around 57 trim with .48 a/r) new turbo
love fab or full-race equal length mani
custom 2.5 inch dp
johnnyracecar or pwr intercooler
450cc injectors
uberdata (free hondata, but you gotta pay to tune it)
boost set at 10psi with boost controller
this will be a more "reliable, better, quality" kit than the one i mentioned above. still, you will need fuel pump, charge pipes, guages, turbo timer, resistor box (only if dsm injectors are used) if i had 2.5k, id go turbo...and this route.
wow that was long....
