Eclipse Amps Need Help!
WKHCivic
SloCivic
I am lookin a pushing 2 12" eclipse subs with a 600 watt max. I want to get an eclipse amp that will put out as close to 600 watts as possible for each sub. So can anyone suggest which amp I need to get if you have an eclpse amp. Let me know what yall think.
cujo613
with 600 watts max you do not want to run at 600. You want to go by the RMS rating not the peak power. Your subs probably take 300 watts each. So get a 600 watt amp. If you have to go with Eclipse plan on spending at least a 15% name surcharge
WKHCivic
SloCivic
So I can only get a 600 watt amp? I am confused because I was told by one of the custom shops I could get an amp that had 600 watt. rms or close to it and be fine.
cujo613
exactly 600 watts rms
$lick Rick
TEOTWAWKI
trust snoops, he knows his s**t ;)
HP Civic 2
The SQ out of eclipses amps are worth it IMHO.
Akiahara96
back!
but there are other amps that perform a bit more for your money.
don't mind my shameless zapco plug... :D but it's true, they're comparable in price but zapcos will outperform the eclipse. yes, they make nice amps, I know, but dollar for dollar you could find something around the same price that's going to perform better.
it just depends on how picky you are. ;)
WKHCivic
SloCivic
Would this be a good eclipse amp to power my subs? Click on the Link. Will this be good? Let me know what you all think. Especially you snoop since you seem to know your stuff.
WKHCivic
SloCivic
One more thing. I hope someone can answer this is it possible to run 3 12's off of an eclipse amp i was told that since they operate at 2 ohms i could. I know i might need a bigger amp if i run 3 but can someone answer that ques for me please.
cujo613
OK follow me here, This is why I dont like Eclipse.
The amp in question is advertised as a full range class D.
That is a lie, by design a class D is only to drive subs and can not reproduce a fuul frequency because of its switching technology. It is almost always a two ohm mono stable amp.
The amp eclipse is showing is just a plain old two chanell. And lying about the specs.
In order to run 3 woofers you need a minimum of a 2 ohm mono amp, wired to 3 8 ohm woofers or dual 4 ohm woofers. Since you are looking at the lower power handling woofer I would go with the 8 ohm woofer.
The amp that you need to buy if you have to go with eclipse it the DA 7122 costing you $799.99 to get a 1000 watts into 2 ohms kinda spendy if you ask me.
if you haven't got the subs already and want to run three subs I would suggest this set up for you and your wallet
http://mobile.jlaudio.com/products_subs.php?series_id=16
and get a memphis st-500 off of e bay.
If you have the woofers already then get a Memphis st-1000 off of e bay. Great solid amp at half the price (if you get it off e bay)
I put more faith in memphis amps then I do Eclipse amps
WKHCivic
SloCivic
Ok i already have 2 of the 12's. If i were to run only the 2 12's do i need the DA 7122 or is that for three subs. If you could just please clear that up because i am a little confused. But thanks for your help so far snoopy.
Akiahara96
back!
eg6_310
Since this amp or amps as the fact may be are only going to be pushing low frequency, sound quality isn't of much importance. Afterall, it's about moving air at that end of the frequency range. If an amp is going to be pushing some tweeters, mid-bass and so on, then sound quality is going to matter. Incidentally, sound quality is going to matter as much as the quality of the audio signal that originates from the head unit.
cujo613
Actually there are amps geared towards sq in bass. Damping factor is the amps ability to control the woofer in both directions, giving it a cleaner hit and higher sq in the bass domain. Not all bass is synthisized. To say sq doesnt matter in bass is kinda ridiculous. :evil:
WKHCivic
SloCivic
I am still confused.
Questions:
1. Can i run three subs with and eclipse amp?
2. Which amp do i need for 2 subs the DA 6213 or DA 7122?
3. If i can fun 3 subs which amp do i need the DA 6213 or DA 7122?
If someone could please clear this up for me it would be greatly appreciated. Snoopy i really trust you so i would like your input.
cujo613
OK in my opinion the eclipse amps are not worth it. You have to get a $799.99 amp to run three subs but if you have to have them the 7122 will run three subs
The 6213 will do for two.
I would really take a look into Memphis amps if you ask me. They are just as good
eg6_310
That is if you are building a SQ competiton level sound system. The average ear on the average consumer isn't trained to notice the subtle differences coming out of the front stage let alone their subs. Hell, look at the most of the systems running in people's cars. Ordinary amps (a la Rockwood, MA Audio or some other crap like that), ordinary 3-way speakers with foam surrounds, ordinary subs, etc. You aren't going to find cars running premier head units, multiple component speakers (in the right locations, mind you), multiple JL W8s or competiton level amps / sound processors (Alpine F-1 for example). Hell, most people have no clue at all, taking the advice of most audio shops who are into just getting s**t out the door, especially more so since everyone's so freakin cheap. I'd say 99% of people out there are happy with a MDF box with carpeting on it. So how ridiculous is my statement based on all of this?
cujo613
The average ear of the consumer will hear it if the salesperson takes thier time to demo and show the difference. Even now I consider JL the highest range of mediocre speaker.
People do buy MA Audio and rockwood even Audiobahn because they are cheap and dont know any better.
But you dont have to have a bunch of processors to get good sound. Or a three way component system. F1 status is good stuff but you dont need it to get great sound. Hell I would take a high end McIntosh deck before I took the F1 status. And dont get me wrong I love alpine but the F1 status is now geared to perfect sonic surround sound reproduction in a vehicle.
