hciv1472
hi everyone, chris here.
2014 EX CVT COUPE
I have some engine oil questions.
1. was thinking about doing my own oil changes and I want to jack up the front of the car. the arrow pointing to the jack point is off center and appears to be pointing to a part of the cross member(frame) that is not the flat part but has like a lip on it that protrudes. what spot do I use? the lip part that is directly in the center or the flat part just to the right of that part.
2. was going to slide race ramps under the wheels after raising the front end and also put jack stands under jack points so with the race ramp blocks, jack stands and front jack placement I will be well protected. any comments about race ramps?
3. lastly, I was going to use penzoil platinum full syn 0w-20 with a Purolator filter as both are cheap at Walmart. should I use the Honda brand full syn oil and filter.
I know its a lot of questions so I thank you in advance
2014 EX CVT COUPE
