leathermaneod
Hi all,
I'm new around here and this is my first post. I have a 04 civic LX with 202k. It's an awesome car and I plan on keeping it till the wheels fall off. I'm not a racer or anything, just trying to make it last and keep it maintained. I'm not new to wrenching and try to do everything myself. Anyway I have two issues at the moment. First, I have an exhaust leak. It's either the manifold gasket or the manifold is cracked. So I'm planning to replace it. What sucks is the cat is built in so the darn thing is expensive. I've been reading that I could just get a header w/out cat and use the little o2 sensor adapter on the downstream sensor to fool the pcm and keep from getting codes and still pass emissions. I'm from PA so passing emissions is a must. What I'm wondering is, is that a reliable fix? Can I rely on that setup with fooling the pcm to pass emissions every year? Or should I just bite the bullet and get a header with cat?
Second issue, I've had a code for the fuel tank pressure sensor for over a year now and I'd like to get it fixed but the sensor is over $100 minimum(no it's not a bad gas cap). Is there any way to wire in a resistor and fool the pcm with that? Or do I have to give in and spend the money on that too? I tried messing around with a potentiometer, but I'm no expert with auto wiring and I didn't get anywhere other than a no start in one configuration lol
Any help greatly appreciated!
