lolopez999
Hello everyone this is my very first post on here, and I'm just basically looking for some insight, and recommendations. I've always been a huge Honda fan my very first car was a 1990 honda prelude, followed by a 1990 civic dx hatch, recently I got a 2000 dx. Unfortunately they were all automatic so I never really did too much to them. Well a couple of days ago I purchased a 1995 ex vin is jhm vin. It came with D16y7 with v-tec at first I thought it was just the valve cover but i found the vtec spool on the rear left of the engine. So the car has a lot of issues including a rusted out exhaust, at first i thought the cat was broken or clogged but i took it to an exhaust shop and it only had 2 resonators and one was rusted through. So i replaced with straight pipe. The car had been running like crap rough idle and limp mode after 5 mins and of course CEL. So i did the jumper thing and got a total of 6 codes 3,4,6,21,22,and 43. I already researched them and know what they are. I still wanted to do a compression test before I put to much into it, supposedly the previous owner did the head job on it. I recently pulled spark plugs and the electrode were full of carbon black as hell. I replaced them, vehicle starts a bit better and idles a little better, but still goes into limp mode. I checked the oil and it was really watery but I'm unsure if it's coolant or uncombusted fuel. I'm planning on doing the oil change to check the oil better, but been really busy with work and school. Other than a compression test, what else should I do to it? Are these codes common? Do you think maybe the block could be cracked? Or broken intake issues? I just don't want to start ordering the parts and waste time and money. I'll post pics of what I have. As of now car starts right away, idles very inconsistently no to high but fluctuates. Doesn't die and doesn't over heat. The exhaust fix seemed to help a bit. But what do you guys think or recommend? What else should I check to make sure it's worth fixing? Don't be too hard on me plz. I am a noob.
