mkvldc4
this is the harness i rewired. The black wires were once blue until they melted and the yellow is ground in the later picture were its connected to the relay the end is blue(had to extend no more yellow wire).the original had three blue wires coming from the fogs one with a male connector (which i assume goes to the red wire with the female connector).And the other Two were hooked up to the relay along with the yellow ground cable from the fogs.Theres a inline 15a fuse (not pictured).
heres the relay .30 (+) is the bottom one ,86 (-),87 (lamp) 85 (switch) this is what the back of the relay box read,
power source with inline 15a to relay (30).
im guessing blue is ground because of the clip looking end it has and red goes to light since it has a female end.and yellow goes to fuse box?why is the two spliced together?
