For Experts: my boosted car is over heating
D16Y6
also another note...After driving about 50-100 miles or so go back over the head studs and re check the torque. Sometimes they tend to loosen after initial torque and if they do then you will be doing the whole thing again...
it seems this torquing process will never end :cry:
D16Y6
guys, my engine code is D16Y6, ebay seller didnt know what is the similler engine so that head gasket will fit. its D16Y8 or D16Y7 ??????
sohclubkid
Sick 6/6
am very sorry about that bro, let me search by my self then before buy it i will show you the item if its correct.
what i understand from your torque, is after done with 60 I have to go back loosen bolts then start with step 1,2,3,4 but in 3 and 4 i have to torque it to 80 instead of 60
dont loosen them after you tq them to 60, just re-tq them to 80.
its the same as the D16y8... so get ARP headstuds for a D16y8 and a gasket for a D16y8 as well...
here is the info.
D16Y8
VTEC
Also available in New Zealand under the code D16Y6
Found in
1999-2000 Honda Civic SR 1.6 Vtec (UK)
1996-1999 Honda Civic EX Sedan
1996-1999 Honda Civic EX Coupe
1996-2000 Honda Civic EX (US)
1996-2000 Honda Civic SI (Canada Only)
1997-2000 Acura 1.6EL (Canada Only)
1996-1997 Honda del Sol Si
1997-2000 Rover 416 Auto
Displacemnt : 1590cc
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Rod Length : 137 MM
Rod/Stroke : 1.52
Compression : 9.6:1
Valvetrain : SOHC VTEC 4 valves per cylinder
Power : 127 hp (94.7 kW, 129 ps) 6600 @ rpm
Torque : 111 ft·lbf (15.35 kg/m, 145.1 Nm) 5500@ rpm
Head Code : P2J
VTEC Switchover : 5500 rpm
Piston Code : P2P
Redline 6900 rpm
Rev Limited To 7200 rpm
ECU Code : P2P
D16Y6
here is the info.
D16Y8
VTEC
Found in
Rod Length : 137 MM
Rod/Stroke : 1.52
Compression : 9.6:1
Head Code : P2J
Piston Code : P2P
Redline 6900 rpm
ECU Code : P2P
great, doupts is answered now.
I really appreciate your efforts man
neoc03
I CRAVE CORNERS
i bet i know the answer...
did you use OEM head bolts? more specifically, did you re-use your old headbolts?
if yes to either of those, your probably gettng head lift. try switching to ARP head studs.
If you don't have a air bubble I can almost guarantee this is your culprit. I don't even reuse my ARPs even though you supposedly can use them up to three times. What's an extra 120 bucks vs. all that work or labor costs.
