The score is just the sum of the frames for the duration of the test. What settings did you use? Changing the resolution, and post-fx, etc will change the final score. Also, what version of furmark? There's drastic performance differences between the different versions.
The point behind the score is so you can make changes to your graphics configuration and be able to compare before and after results. The higher the number, the better the performance.
