Fuel pump no power
saabguy
That's exactly what we did because my ecu is tuned and I didn't want to lose the tune.
Sent from my SGH-M819N using Tapatalk
Diana Nam
this is whats it looks like inside the ecu i have hondata S300 installed in this p28 ecu with clear cover but this is what honda ecu looks like on the inside
Diana Nam
ok that makes more sense but your tune should be in the chip unless you directly solder the chip normally you put the chip socket on first and you can just put in the new chip or remove it
Diana Nam
also if you remove your chip from the ecu it goes back to using stock tune
saabguy
Somehow then it kept the tune. The electrician I was working with told me it would keep and it did. We just got an ecu from a junk yard. Italy tweaking I guess.
Diana Nam
the tune will never disappear as long as the chip is fine and not burnt makes it much cheaper to solder things on depending..
