My Homemade turbo Build...
Ok, Got my oil lines in... Im now one step closer to a turbo'd car.
Oil return, and feed lines:
So far nothing leaks, (whew) and car runs normal.
Getting that pan off is a b***h... but tapping it was easy. I put a washer on the outside, and a nut on inside, and smothered the whole thing w/ jbweld.
Oil return line back into pan: (jbweld is just a precaution, should seal anyway)
Oil feed line:
t'd off pressure sensor behind block, above oil fiter:
ghetto intercooler hose: (it'll work!!!)
HF manifold with o2 plug drilled for EGT probe:
random brass fittings:
gauges installed: (had to return a/f, shipping a new one out)
DIY fuel pressure gauge:
drilled out this brass plug, threaded with a brass 90' and screwed $15 dollar pressure gauge in:
as you can see, I tried to cut an notch and remove with a screwriver. Turns out its NOT threaded. So I had to drill, and tap.
Oil feed line:
