ImportFan1
Super Moderator
Yo Jay, my bad bad for not responding sooner. The conversion is very easy man. The only thing that i can complain about was that my car was on jack stands. Jack stands as high as they could go. A car lift would of made it easier on my back. when attaching the e-brake cable i think its easier to bolt the cable to the caliper and e-brake lever First, then bolt the cable to the chassis via the brackets. i did it the opposite way. i first bolted the cable to the chassis via the bracket, then attached the cable to the caliper from the lever. When are you doing yours? I recommend to replace the trailing arm bushings while your at it, and if you can, replace the wheel hub bearings also.yo hector how was your rear disk conversion how hard was it to do it?.
