$lick Rick
TEOTWAWKI
not reliablyslambed_civic said:mike, 100 shot would be possible, but pushing it, right?
thanks mike. j/p no nitrous is really reliable, now is it?Todd said:not reliably
you could do a 50 shot if you adjust the timing and keep it pretty darn reliable.slambed_civic said:thanks mike. j/p no nitrous is really reliable, now is it?
true. very very true.Todd said:you could do a 50 shot if you adjust the timing and keep it pretty darn reliable.
all power gains in general will decrease the reliability of your econobox engine.
thats really pushing it. i am not a fan of nitrous at all, because the only really reliable way to run more than a 50 shot or so is with a custom tune, using a direct port system. i dont like wet systems at all, and the fpr of a dry system is just that- a crappy fpr. the electronic boxes arent much better. the problem with nitrous systems is they only really work on completely stock motors. if you have any mods to them, ie. cam, port work, higher compression, a frank motor, etc, the electronics dont compensate for that, and you end up blowing your motor up. and for me, if your gonna spend the time and money for a custom tuning job, you might as well put a turbo on instead of the direct port kit, which are pretty damn expensive, and at a 100 shot, you are gonna be refilling bottles pretty often. and the delivery system itself is a problem. even with a 50 shot, as you go down the track, the bottle pressure changes, as n2o is released. the pressure change is only registered by some systems, and even then, its not an exact science to compensate for it. there are better ways to get hp out th ere.slambed_civic said:mike, 100 shot would be possible, but pushing it, right?
werd. no hard feelings.allmotorz said:if u havent notice, i dont drive a honda..so i cant tell what gen does what and have what and where they max out at.
but yeah i agree, just turbo the damn thing...
handlebarsfsr said:...direct port, along with custom tuning, is the only way to go. and your stock bottom end wont last very long on that either.
