HELP !! Leaking oil. Broke oil pan thread or screw?
Gradeless
RICE FTMFW !
around here for like 30 bucks you can get your pan rethreaded
that sux for me then i guess, i went to like four places and asked them if they would do it and they said it would be worthless because it was alluminum, as stated before. It was a good experiance though i am glad i took the time to do this myself
umair
hey..that fix will hold. He put a screw inside of a screw which he should have done the first time. Just keep checking your oil every other day at first to make sure its not leaking.
umair
if you need to change the pan i would not reccomend you doing it yourself. You have to be careful when you tighten the oil pan nuts..if you over tighten them your f*cked. also get the aluminum one, its lighter which means more speed ;)
TilhasBB
NO LEAKS =) I think this actually worked ;)
