brianseg
Ok heres one for you and if anybody can help i'll be very greatful
Ok ive had my share of honda's mainly civic's and integra's well i pick up a 94 civic sedan d16z6 5sp for 500 dollars guy said it just stoped running didnt know why. i bought the car got it to my house and started working on it. since ive had it,I took the head off had it machined to check for any cracks,bent valves and so on,put a new head gasket rebuld kit on it replaced the thermostat,spark plugs,spark plug wires,distributer,fuel pump,injector's,fuel filter,pretty much everything to keep a car running was replaced.
well i got finished putting the timing belt on got everything lined up at tdc went to go start it wouldnt start just crank.did a compression test each cylinder was pushing 150 cylinder 4 had 151.so its got great compression,check the spark plugs made sure they was firing right (past) checked the injectors made sure they was putting out fuel (past) ive done everything somebody with my abilty can do.
okay, if the car sits over night i can go out there turn the key it will fire up and putter for like 10 seconds and shut right back off wont start again the rest of the day.I can not figer out why this car will not start ive even changed the computer to see if that was the cause of it and still just turn over nothing. i know the motor is good do to the compression im getting from each cylinder but im down on my luck with figering out why this car wont start maybe it just dont like me who knows lol. but if anybody might know what the cause is please let me kno. the only other thing i can think of is maybe some how the crankshaft pully is not lined up right with the gear but i dont know how it could of happend
