That one EF
Hey, I have a 1988 Honda Civic EF, 3 door hatch. D15b1 Dpfi,
Car broke down last winter due to nasty intake mani,
Got a new intake manifold, New IACV valve, New pcv valve, new pcv valve hose and cleaned ventilator.
Replaced the intake manifold gasket, fixed vacuum leaks, replaced throttle body and injectors, cleaned throttle plates. Messed with idle, it's all okay, But, the car still revs up like it's at full throttle. goes all the way to 5k on the damn dot. I won't let it bang the limiter but it will if I let it. Took off the negative for 5-15 minutes. Same issue. Even when throttle cable is un hooked.
