If your rear upper arms are STOCK/OEM they should look like the piece pictured at the top. OEM is not adjustable, and with a ride height lower than stock, you WILL have negative rear camber
if your rear upper arms are NOT OEM and ARE ADJUSTABLE, they will look like the lower pictured part. If they are like this, your camber can be adjusted both positively and negatively. Plain and simple.
Take a picture of your setup and post it here without needing to describe the situation. The vast majority of us should be able to tell you what's what with just a photo.
![](http://www.georgebelton.com/6g.civic.tech/camber/rear_03.jpg)
