5k for a 98 honda civic vtech is too much!!!!!! It has to be low miliege, perfect condition inside and out, and hella updated inside the engine. And with bad ass rims and custom suspension. Other than that, the car is worth 3 thousand MAX, assuming it is in excellent condition. I mean no dents, perfect paint, no stains or cuts in the inside, and no oil leakage anywhere.
I own a 1997 honda civic EX, SOHC vtech. and My car has reached its stage of its life where all the gaskets are beginning to fail. Before this year, my car was running perfectly since I bought it in 7 years ago, for 8k. It only had 82,000 miles, now it has 182,000 miles. I had to replace, the radiator, all the hoses, water pump, timing belt, valve cover gasket, distributor and its gaskets, vtech gaskets, HEAD GASKET, thermostat, My bearings went out, so replace those along with both axles, 3 wheel studs broke off, and not to mention the automatic windows are a PAIN IN THE ASS. These cars are known to get messed up. I had to replace the window regulator and constantly have to lubricant the side of the windows. My transmission is working perfectly, thank god for that.
I think my car will be running fine for another 150,000 miles! When I replaced these gaskets and parts, they were old and shitty. These things are not meant to last forever. If your going to get a 6th generation, be aware that it too, has reached the mid point of its life and its going to need some replacements. After you replaced these things, I think it will be a reliable and dependable vehicle.
Based on some of my research, cars go down hill after the age of 10 years.
Also, if you are looking for a vehicle for 5k, then consider getting a 2000 civic, or lately I have been checking out a 2005 honda civic with the right body kit, rims, and lowered. Without these, it looks like a car that is for chicks.
