What dash did you use? The old one (96-98)? Or the new one(99-00)??I just done this and it is very simple but takes a lot of time! the two hoses do take a bit to yank off but i'm happy with the result. I still dont understand the wiring for the defrost like what needs to be cut and soldered together. need pics for that lol.
i took out my 96 dash and used the 00 dash from an rx ek9. my car is a UKDM RHD though, does this make any difference? also thanks for the info!What dash did you use? The old one (96-98)? Or the new one(99-00)??
If you used the old one:
http://honda-tech.com/showthread.php?t=2320558
check this thread and the 2 last pictures is what you need to do. The first plug (little green) is the old plug that plugs into the defrost switch of the old climate console.(now it plugs nowhere) The second big blue plug is infront of the heater
If you used the new dash:
You should tap the wire of the second picture (blue plug) to the same color wire of the big green plug that sits on the fuse box. You should search the wires a little bit. I dont know if this big green plug is infront of the fuse box or from behind, as I did the whole conversion with the old dash, so I followed the fist way!
Doesn't what Chameleon says help?anyone able to help me on this one? my old defroster plug is not green but shows similar wires. so i'm assuming its the same. so the blue and yellow wires. go into the baby blue loom. but which one? the one that goes into the heater? the one that goes from the climate control itself?i guess it would be the same anyway right?
thanks
hmmm neither of them match my looms what so ever. but that blue one does show. maybe because i'm using the jdm loom from the ek9 Rx... hmmm, i guess it's just the same as it's just that blue wire anyway! thanks for the helpHere is the compare of the old and new plug that goes to the heater core.
http://repo.jackmoves.com/v/erik/album106/album228/SANY0864.jpg.html
This top right cable needs to be tapped. Now from what I can understand of Chameleon's words, you must try to find a same color cable in the fuse box (green big plug) and tap it together.
Sorry to bring up an old thread but any info would help I have a 99 climate control with the main harness on it with all the knobs etc. So all I would have to grab is the heater motor which you said was 3 bolts? And what brackets are you talking about I have no ac so I dony need to worry about that thanksvery good write up however all this is not nessisary, you dont need the heater from the 99+ you only need a few brackets, you dont need to remove the dash.
in all it took me about 2 hours to do the swap, which was easier than putting on my exhaust.
all you need from a 99+ are
climate controls
99+ harness for climate control
12v relay
the bottom of the blower motor (which unscrews in about 3 seconds)
a few brackets and the electronic heater levers, which all BOLT RIGHT IN! so we need to spread the work that this is a plug and play mod....i did this all in about 2 hours.
