ThanksEran said:Good writeup connie .....
you know some ricers are going to use this for the wrong things
after you spray the primer you should take a tack rag and go over the primer. picks up all the over spray and any dirt, allows it to be a whole lot smoother.Step 6- Using Krylon Gray Primer Paint primer panels applying only one coat.
(Primer optional or if different color than paint; Skip to Step 8.)
Step 7- Let primer dry for 15 minutes.
Step 8- Using Krylon Fusion for Plastic Paint(any color you choose), shake can. From left to right spray a light coat of paint onto the panel.
(Be sure to cover all visible sides.)
[Step 3- Remove seats with a 14mm socket for bolts.
