how to??
Handlebars
None Taken.
BluCivicSi said:
right now i have roughly 8500 dollars i know thats more than enought to make a turbo kit but i am still gonna need to tune and all the other good stuff and build my block and get hondata stuff like that.. I do not plan on me installing it.. there is a "specialty shop" thats giving me a hella deal 1200 installed and fully tuned... my hp goals are 275-350hp (its possible) and intended use is everyday driver...
then you dont need to build the bottom end, a stock b16a is fine for 300 whp. so is any b series motor (maybe not the b20, thats as much luck as it is tuning, has to do with poor sleeved design of the early motors). it certainly wouldnt hurt to build the bottom end, but its not necessary. but 300+ whp on a b16, your gonna be dealin with some lag. the more your willing to spend on a turbo, the less you will have. if you want the least lag, a gt series turbo (a gt28rs would be a great turbo) but they are expensive. otherwise, a regular t3/4 hybrid will get you there. on the street, you may find that 300 whp is too much (getting street tires to hold 250+ is a stretch, especially if you dont have an lsd.) and go with a lower boost pressure. a simple cast manifold, properly braced, will work fine, and you can buy a regular set of intercooler pipes (some from any off the shelf kit like drag, fmax, etc all work fine) the intercooler of your choice, a tial 38mm wastegate, the lines and fittings from any kit again will work. http://www.beesandgoats.com/boostfaq/g2icturbo.html read that. love it. if you still have your greddy kit, you can use a 20g upgrade turbo, a big intercooler, a hondata, and your set, everything else will work.
Inigo Montoya
powered by boost
with those goals...
a johnnyracecar.com IC will work fine
I agree with Handles on the GT28RS turbo... the "disco potato" is damn sexy. http://store.yahoo.com/cheapturbo/gagtdpo.html
only $1100 new there... and you will be making power from under 3grand until redline
with that much cash though.. you should really consider a k24a2 (k24 is from the new crv, and the a2 from the RSX-S head) turbo. It would be INCREDIBLE. (and $$$)
You're definitely going to need an LSD though.. go Quaife so you can get the life-time warranty...
and I would recomend a LoveFab SS tubular manifold (cuz Cody's a pimp.. and because it has life-time warranty also)
BluCivicSi
ok like you said a lower boost.. but what if i wanted to boost like say 8psi daily and when i go out to the track or something i wanted a bit more like around 15 would the cast mani still hold up?"
Handlebars
None Taken.
8-15 psi on a t25 or on a t3/4. they are NOT the same thing. you can get 300 whp on 8 psi from a t3/4. you cant get 300 whp even on 30 psi on a t25. its about flow, not psi. a cast mani would be fine, but the stock bottom end wont. 10.5 compression and 15 psi of boost is otherworldy, and you will detonate. i suggest more research first.
