I cant take it anymore
CivicLX97
i installed the fuel pump today and the car seems to idle a tiny bit higher but not much and i tried to put that bypass back in and it did the same thing. it wont let the car start....im so confused why the hell is that happening...also once i installed the fuel pump i took the car out for a ride and wanted to see how it performed under a little boost, and once i try to accelerate and get out of vacuum the car stutters big time and wont get past 2 psi, last week after i installed my boost controller i could easily get up to 6 psi, it feels like the exhaust wont let the turbo spin anymore but i cant tell..anyone know what that would mean?
oc_civic
think its at all likely the bipass is bad.. lol ;)
CivicLX97
this isnt xs s**t...wrong thread...i tried a check valve too like the aquarium style and it did the same thing, i dont think the bypass is bad...man im stumped
Rubixcu7
Not Fittin In...
could the ECU make the ar be in "LIMP MODE"? just a thought... and no offence... but i know the map bypass blows in one way and not out the other... is it upside down? just my two cents...
soldiaboy
343 FDNY
93BLueEgHaTcH said:
if i buy your turbo can you help me install it? i have the same car as you i think
you want him to install the kit so you can have the same problems hes having?
Blazed
f**k The Powers That B
man i'll have some1 knowledgable to do my set up for me..i aint touching that stuff...:nono:
CivicLX97
everything is installed right...i let the shop that i bought it from take a look at it and everythings cool especially now that i installed the fuel pump...no the map bypass is not upside down, i have no clue and still havent fixed it..also even with the fuel pump installed, when its really hot outside i have to push the gas a little bit to start the car, what could this be
Mr. Jollypants
Mr. f**king Jollypants
Check your fuel filter and fuel lines, make sure they aren't being crimped and that the fuel filter isn't clogged.
