Idle issues
montenegrobryan5
Could you hear it if you put your ear on the fuel pump cover? Because I removed the seat and I placed my ear near the fuel pump but didn't hear anything
montenegrobryan5
When I hooked the fuel pressure tester to the fuel filter, there was a loud buzzing noise coming from the driver side, isn't the main relay located around that area? It was buzzing when I turned the key on /engine off
montenegrobryan5
Does it have to be on the thermostat housing? Because it's located somewhere else
montenegrobryan5
I checked the ground wire to the thermostat housing and u were right I left the ground loose and it turned on right away
