Inner fender splash shields
damon.n.noriega
I need help on buying inner fender wells for my 2014 Honda civic si sedan. Is this just a dealer part or do they have aftermarket. My car is dropped and I went through 1 set. 1st set bought from dealer. It's expensive from dealer oem. I'd rather go with aftermarket if I'm going to lose my inner fender wells. I hate nyc...lol. roads are horrible and I don't want to lift my car up....sits perfect. Any help would be highly appreciated!!!
Sent from my SM-G935V using Tapatalk
damon.n.noriega
I wouldn't go that far, but you're welcome anyways :thumbs up If salt is that bad then you might as well spray those exposed fender wells with undercoating to prevent as much inevitable rusting as possible. I also suggest you consider getting carefully crafty with a heat gun and try to mold out a little extra clearance on the next pair of fender liners so you can hopefully make them last much longer.
If salt is that bad then you might as well spray those exposed fender well with undercoating to prevent as much inevitable rusting as possible. I
This. Do it. Go to a place and drop a couple hundred on somewhere that will have a lifetime warranty. It's worth it. I go every November and they re-undercoat it free of charge. Not sure where in NY you are but here in Rochester I took my RSX to Ziebart. They've done a good job; I've had it for 3 winters thus far.
