CivicFreak26 said:
oh i have a question to ask too. which is better, wiring your neons up to your car battery or just using the plugin for the 12 volt plugin in the dash?
thanks,
CivicFreak26
dont wire it directly to the battery positive terminal. Sometimes the connection starts corosion on the battery.
Here's what I did with my neons...
went to autozone and purchased a fuse splitter or something (dont remember the exact name, but only autozone carries it I believe). it basically turns one of your fuses (under the driver dash) into a Y fuse connector. One of the fuses is for wherever you plugged this adaptor into, and the other fuse is for the neons. From this connector there is a positive wire coming out of it.
All you do is connect the positive wire to that adapter, then to a switch, then to the neons. U take the ground from the neons and just ground it to any nut or bolt that is touching the frame of the car. Works great! haven't had a problem with them yet! And it's hooked up to a fuse
clean install, and no wires anywhere if you hide it right. Also makes it easy so you dont have to splice into any existing wires.
PM me if you want pics...i can prolly go out and take a picture of the lil adapter thing or something. costs like 4 bucks?
