its the S68!!! like I have told you.yea. nice S58 Bucket Seat.
The question everyone should be askin you is why aren't you on dump mode?
the material forms, but the side bolsters don't form. i'll bet u put a 38" waist in there and those side bolsters break.did you look on memoryfab? The S58 has a bit of a different design on the padding for your back, and had a little pad where your legs rest. Maybe its because the material forms to your body so over time it will form to a 38 waist more comfortably.
well both you and I won't have to worry about that.the material forms, but the side bolsters don't form. i'll bet u put a 38" waist in there and those side bolsters break.
if the seat opens up, then its probably not a good idea to let other people drive it in the early stages...Taken from MemoryFab.com
"This carbon fiber seat has been known to fit waists 32-38 and height 5 ft-4 inches to 6 feet with no modifcations. The heat sensitive foam and composite honeycomb core adjusts to the drivers size and forms to a glove like fit over time"
i think the seat its self adjusts to size not just the padding
at least people that are similar to my shape.if the seat opens up, then its probably not a good idea to let other people drive it in the early stages...
