What is the difference between wanting a louder intake and a louder BOV? They both regard a noise factor, and you are concerned about the noise output that is created by it. Instead of asking which BOV is the loudest, why don't you try asking which BOV is the best? If you are all concerned about noise, then what are you classified as when pertaining to a question like this?
If you want the loudest BOV, go with a Turbo XS RFL because it is one of the loudest. But it's also the crappiest piece of s**t in the BOV industry. Show me one person who has put down impressive numbers with
REAL boost, using the only BOV line up that features washers and a bedspring to adjust valve tension.
![Rolling Eyes :roll: :roll:](/forum/styles/default/xenforo/smilies/icon_rolleyes.gif)
You won't find any because the people who put down good numbers in turbo'd Honda's are smart. Smart people research. Research leads to straying away from crappy parts like Turbo XS BOV's. [Soap box mode off]
With that said, I will recommend one kick ass BOV that looks pimp, sounds pimp, will handle any type of boost you throw at it, and has been tried and proven with the DSM, MKIV Supra, and now finally the Honda guys::
The Tial BOV. 50mm valve (largest on market which means largest area of released air at discharge), and a 360 radius release (which means it doesn't discharge from just one side like all other BOV's), which in turn means
loud. It's probably the pimpest sounding BOV by my likings by far. Sounds like an extremely loud crack of a whip at a WOT shift. The best part about it, is that it holds boost (30psi is no problem for these BOV's).
