I forgot to mention earlier, the whole drain & fill process was rather easy once the bolts broke loose. I definitely needed enough floor clearance to properly leverage the breaker bar. Do note that a long thin-necked narrow funnel will make it very easy to fill through the speed sensor hole, which is held in by just one 10mm bolt thats top-mounted for easy access. I didn't have a thin long funnel but used two shorter funnels that's worked fine after I got a little overzealous and poured too fast at one point and spilled over a little. With that said, pour slowly as you only need 2 quarts so it wont take long anyways.
