alright im hooking up my 2.5bap map sensor....i hooked up the 3 wires but on the vacuum source do i connect it to my vacuum manifold....or to the original spot the map sensor went to?
either one, as long as its getting vacuum you're fine. But just to be safe I'd put it to its original place. As soon as you start the car you'll know if the vacuum source is sufficient or not.alright im hooking up my 2.5bap map sensor....i hooked up the 3 wires but on the vacuum source do i connect it to my vacuum manifold....or to the original spot the map sensor went to?
