i'm running a .70 trim with a .63 cold side and a .84 exhaust.... on my b18b...running 7 psi's. the turbo is way too big for my motor... 1st gear i barely hit full spool...
![Sad :( :(](/forum/styles/default/xenforo/smilies/icon_sad.gif)
(redline is at 7000) but in all other gears its at 4500-5000 rpms... when i dynoed the car it had 210 whp at 6500. with about 185 tq at 5200. also its untuned. running the fmu right now. i have the vafc 2 w/ dsm 450's on the side. just need to pay off the ticket first then i'll be able to save up for tuning... gaol is for 250 whp atleast... also i think the maximun amount of boost you should run is about 9-10 with a stock d series... but i recommend you replacing the headgasket to a much stronger one like cometic. also change your head studs because around those boost levels it happens happen.
